Here is a 0-100 run I did last month, truck seems to run okay. Just wanted some options on max. the power. The only problem I have is my shift points, but I am a little unsure what to do (I know where it is in the menu of the u7137). If you could explain this to me as well.
Thanks Again,
Josh
Could Someone Help Me Out - Datalog Attached
JHunter1984
Charger250
RE: Could Someone Help Me Out - Datalog Attached
Remove 1% fuel at high rpm range. Also advance the timing and repeat until you get more than 0kr then remove it until its just at 0.
JHunter1984
Forgot to mention I was running 9r06 on 91 octane tune (can not get 93 here in california). I am updating to 9r08 right now, do not think it makes a difference on my truck. But firgured it was the latest crom.
Also have a 90mm BBK T.B. coming this week
JHunter1984
Charger520 think I would be safe just putting in 93 tune, or modify the 91 tune as specified above?
