98 tt mustang gt custom tune trouble codes p1445,p0136,p0156
eminit
Post by eminit »
1. U7146
2. Predator v.9r03
3. 98 ford mustang gt
I just got my car of the dyno yesterday and they were unable to figure out why these codes keep popping up.
P1445-Evaporative Emission System Purge Flow Sensor Circuit High Input
p0136-O2 Sensor Circuit Bank 1 Sensor 2 see p02270 , p02271
p0156-O2 Sensor Circuit Bank 2 Sensor 2 see p02272 , p02273
they were writing the tune through the predator, I do have a Cmr chip in the comp. as well though. They were unsure if that was the reason and it was over riding the predator
The car is a 98 tt mustang gt
the car has a aromotive a1000 pump,
72 pound injectors,
4.6 .30 over pi heads,
t-56 magnum,
4.10 rear gear,
forced induction,
78 mm BBk upper intake plenum/TB,
Typhoon intake manifold,
MMR stage 3 pi heads,
MMR stage 2 custum grind cams,
93 octane fuel,
high flow cats
584.81 rwhp 548.72 ft-lbs torque @ 14 degrees timing
RE: 98 tt mustang gt custom tune trouble codes p1445,p0136,p
Cant use a chip and a flash tool
I am shocked it even let you flash it with the chip installed.
Return to “Predator Ford Gas”
