shift problem
shift problem
I have a 99 seirra 6.0 I can't seem to get the 2nd gear shift right. It really hits hard if I'm half throttle or beter and I mean break you neck. If I put a stock tune in is fine. The touqe mang is on as well
RE: shift problem
what is the revision?
Re: shift problem
I have a question since I'm having a similar issue with the tune installed. Have you scanned the PCM for codes with the Predator? And, if yes, are you getting a P0748 code? This code is for an electrical issue with the Pressure Control Solenoid.brody1 wrote:I have a 99 seirra 6.0 I can't seem to get the 2nd gear shift right. It really hits hard if I'm half throttle or beter and I mean break you neck. If I put a stock tune in is fine. The touqe mang is on as well
Mine shifts hard like you are talking about but only after I've had a WOT event like when passing on the highway. It goes away with the next ignition cycle and all seems to be good again, except, there's this code lingering in the PCM all the time. Right now I have the stock tune in the truck and I can't get this code to trip again. I'm thinking the problem is in the Predator tune I'm using.
I'm curious where this thread will lead.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
RE: Re: shift problem
No I don't get that code its just very stiff shift to stiff
silveradohero
Same thing with my 07 silverado when using the pretuned diablo tune. cant seem to figure it out and no one knows anything bout it. thinkin of having lew do a tune and see if it goes away but would hate to spend the money if it doen't
