Corvette Servo in 07' Z-71 MAX 6.0L gas
reredrider
I put the Corvette Servo in the other day, wow...it changes just a smooth under normal driving conditions. I didnt think it had changed anything until I got in it. It held gear a little bit longer and then it changed in to 2nd and I think I heard the new 33s chirp on the back. Well worth the $30 to wake the beast up some more and it just drives around town better too. Along with the Custom tune, that alomost 7000lb truck is fast.
RE: Corvette Servo in 07
i been thinkin bout doin that to mine im not much of a trans person. what do u gotta do to change it an what servo is it?
2008 silverado 1500
heavy duty 5.3L
k&n cai
poweraid tb spacer
muffler removed
Edel ceramic coated shorty headers
heavy duty 5.3L
k&n cai
poweraid tb spacer
muffler removed
Re: Corvette Servo in 07' Z-71 MAX 6.0L gas
I'll say Amen to installing the corvette servo. I can chirp the tires with just the canned 87 octane tune that came in the Predator. I'm just waiting to see what happens with a custom tune by Lew.reredrider wrote:I put the Corvette Servo in the other day, wow...it changes just a smooth under normal driving conditions. I didnt think it had changed anything until I got in it. It held gear a little bit longer and then it changed in to 2nd and I think I heard the new 33s chirp on the back. Well worth the $30 to wake the beast up some more and it just drives around town better too. Along with the Custom tune, that alomost 7000lb truck is fast.
It's an easy install except for getting that dang snap ring back on. It's the trickiest and hardest part of the install that you need to make sure is done right or you'll blow out all your tranny fluid on the highway. You can get them in a few places like eBay for about $20 including shipping. I got mine from Oregon Performance Transmission.ftrspeedy wrote:i been thinkin bout doin that to mine im not much of a trans person. what do u gotta do to change it an what servo is it?
The servo is located on the passenger side of the tranny behind a heat shield. There's lots of info about the install on a number of GM truck forums. I recommend looking at those sites about the install process. Just search "corvette servo." It would take too long to explain everything here.
I'll say this much about the Predator; it has certainly woke-up my truck and turned it into a beast. The servo simply enhances the experience.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
RE: Re: Corvette Servo in 07
ok thx for the info.
2008 silverado 1500
heavy duty 5.3L
k&n cai
poweraid tb spacer
muffler removed
heavy duty 5.3L
k&n cai
poweraid tb spacer
muffler removed
reredrider
Get it from oregon performance. It is real easy to install just take your time putting it back in and make sure you dont cut the blue ring. Press it in hard a couple times to make sure it seats well and also that is how far you have to have it in to get the retainer clip on at the end. The retainer clip will take you longer that the rest of everything. Just take your time.
Lew will fine tune the wide open shift hit after you put one in.
