freezing when logging analog inputs
on a u7137 06 wrangler i wired in a aem a/f to datalog..whenever i create a new logg and record..it will record for a few secs then lock up the trinity every time..i thought it was my wiring pulled the 2.5mm plug out tried several times to record with nothing even going into the unit and it still locsk up..wierd..perhaps a bug with the latest incremental???
RE: freezing when logging analog inputs
I'm having a similiar issue ever since I used my Trinity(U7134) on a U7135 and did a beta incremental update for 09 Challenger dead batteries.
Monitoring is fine, but I can't seem to get a log recorded internally.
Mine never locks up per se'. The log seems to start for a fraction of a second but the blinks out to the "create a new log" screen. If I immediately try to record another log, I get an "error" message. All other functions appear to work after I get the error message. I'll continue to get the error message until I reboot the Trinity.
In the past, nearly the same situation occured when I'd inadvertantly select a "DCX Hemi" layout instead of the usual layout for my SRT-4. I figured there was some sort of PID conflict, idk.
funny thing is, I did recently add some PIDs that maybe causing the issue similiar to using the wrong layout. Although the PIDs work perfectly when monitoring, just not recording. I'm going to remove the new PIDs and retest.
I usually log with a laptop but I haven't tried it yet to see if the issue persist with Dataviewer.
Craigbbb - Can you export the recorded log using DataViewer (even a few seconds is fine). That contain the "lock up" behavior?
duster360 - Please export the dash with your added PIDs. I'll give it a try on the bench.
Craigbbb - I had this exact same issue. You can read all about it here
http://www.diablosport.com/index.php?na ... ic&t=24066
Jimb - I sent this Trinity back in as requested some time back. The RMA # is 11574. Is there any status on this I can get?
Craigbbb - please let me know how you get yours resolved.
2004 DR QC, 5.7, CAI, 6.1 rods/springs, KRC 210 cam, Pacesetter LTs, x-pipe- no cats, dual DMH cutouts, 6.1 ignition conversion, Auburn LSD w/456 gears, e-fan, powerwire, Sonnax line boost, Trinity CMR 93 tuned, Innovate LC-1
Yes, received your Trinity early this week. Was able to get to fail, but don't have any root cause yet.
Re: RE: freezing when logging analog inputs
Sorry Jim, I lost track of this thread.jimb wrote:duster360 - Please export the dash with your added PIDs. I'll give it a try on the bench.
Again Monitoring and live streaming on the PC works fine with these PIDs, just recording with the Trinity doesn't work
- DAVE_SRT4.TDS
- (978 Bytes) Downloaded 221 times
RE: Re: RE: freezing when logging analog inputs
cant record a log unit it totally locked after 2-3secs..has there been any solution to this issue? i was trying to monitor air fuel live streaming on my laptop it it would only record a few secs then stop just like the trinity
Yes there is a solution than could affect internal logging. Will have Mike L send you u7137_1t07cd Crom.
email sent.
Update. Problem still exists with 1r08
I did notice that the complete layout(+8 more PIDs) works just fine while you're adding guages in "Logging." It was only after I saved the Layout and tried to use it again in Logging or Monitoring did I get an error. The attached layout works. But if I add anymore guages(Example VAC, Ambient temp,) AND save the layout, an error occurs and neither Logging nor Monitoring will work.
Asside: all my old layouts show up when browsing the Trinity with DS Downloader. They're all under the U7134 folder. I'm not sure how to access them within the Trinity though.
- SRT4.TDS
- (1018 Bytes) Downloaded 205 times
Needless Torque Calibrations
www.needlesstorque.com
Any thoughts Jim?
I thought we had this problem resolved with SRT4/SCI bus interfaces > 8 pids. I'll need to setup on bench using your dash and see IF I can recreate it.
As for salvaging your dashes, DSDL should let you export them out from U7134 folder and import to dcx_gas folder. Or, put them on SDCard and import.
Re: RE: Re: RE: freezing when logging analog inputs
It works just fine once as long as you don't back out and save the layout. But when you save the layout and try to use it a second time, it fails.jimb wrote:I thought we had this problem resolved with SRT4/SCI bus interfaces > 8 pids. I'll need to setup on bench using your dash and see IF I can recreate it.
