battery drain for chally update no worky...help..
i did the update for the battery drain on the challenger, its 1r07b and the trinity confirms this update is in it. but no sleep time buttons under options???but it does have a new option thats called select oem ,and it says for future use?? any help....
latvat
Kahler
Mine never never ever drained my battery. I left it plugged in all the time. For days. A few wekks ago I went on a trip after I read about this happening, I knew mine was ok. Then I shut it off at the hotel, and 24hrs later DEAD. Had to get jumped. Got home left pluged in and DEAD again. Why all the sudden ? How ?
Anyway I just did some updating how do I know the repair is downloaded, and its the fix for this. ?
Link to post containing filelatvat wrote:I must be really stupid, but I can't find 1t07ca_update.crom ... only 1r07b is visible and that was easy to update into Trinity... please help...because also my challenger suffers battery dying...
http://www.diablosport.com/index.php?na ... 734#145734
latvat
Yeap Thanks to TIGwelder, I have read that thread before but I am looking for where to download this 1t07ca_update.crom since if I go Support -> Updates/Downloads, choose Trinity and enter Trinity serial number...all I can see in U7135 row is trinity_u7135-1r07b_update.crom and not 1t07ca_update.crom like previous posts give me understand...so where is the problem ? perhaps someone can send it to me by private message...thanks for helping
In order to see the file to download in that post you must be logged into these forums. Otherwise the section of the post with the update file is not visible.
You should see
trinity_u7135-1t07ca_update.crom
Description:
Download
Filename: trinity_u7135-1t07ca_update.crom
Filesize: 1.07 MB
Downloaded: 48 Time(s)
and then a link on the right that says "Download"
Click that link a download it right from that post and save it locally on your computer.Then once in the DSdownloader you choose the file you downloaded as your update file.
Check your PM
You should see
Description:
Download
Filesize: 1.07 MB
Check your PM
latvat
latvat
latvat
