Leaving trinity connected drains battery on my challenger
SRTorRed6sp
RE: Re: RE: Fixed the battery drain but note this
Post by SRTorRed6sp »
Yea Mike. I have confirmed it twice now. 2 times I left it sit for a week hooked up and it went dead. Then I tried disconnecting it and it sits for a week no probem.
TIGwelder
Post by TIGwelder »
The fix works. Long term storage...I wouldn't suggest leaving it hooked up.
It's a lot better than it was, that's for sure. I will continue to disconnect it since I don't drive the car enough to always have the battery recharging to a full charge. My car may sit a week or more between drives.
It's drains a lot slower though and doesn't seem to be keeping anything active anymore and quick draining. Where it would drain .10 during a period of time, it will now drain like .01
Since there are people not using their vehicles as daily drivers...
Either hard code a max time before forced power off
OR
New param idea "Power off completely after X days"
0=disabled
Then we push a button to wake it when we start the car.
- How it works
On every "monitoring_sleep_interval" check, it increments a counter.
Then compares counter to a max value
If max value is exceeded then power off completely
# === Basic logic behind idea ===
# I'll assume there is no system clock, so we'll create a max time based on seconds
# From added param sleep interval
$monitoring_sleep_interval=30
# From new idea for config param
$monitoring_days=2
# Reference:
# 3600 seconds in an hour
# 86400 seconds in a day
# Calculate max seconds by multiplying days by seconds in day
$power_off_seconds = ( $monitoring_days * 86400 )
# Convert max seconds into a counter based on sleep_interval increments
# So 2 days of seconds divided by 30...the counter would be 5760
$monitoring_max = ( $power_off_seconds / $monitoring _sleep_interval )
# Add to sleep check code
# if monitoring_days not equal to 0
# Increment sleep check counter
$monitoring_sleep_count ++
# Check to see if counter has reached max counter value
# Max value is 5760 in example
# If so...power down completely
if monitoring_sleep_count >= $monitoring_max then power off
# === Bottom of logic ===
Den
forcefedjunkie
Post by forcefedjunkie »
This update is not on the download page and I don't see it in this thread. Am I missing it somewhere?
the fix is in the latest incremental update available.
forcefedjunkie
I've downloaded the latest, trinity_u7135-1r07b_update.crom. But I don't see this option under "options" as described. I have selected 2010 Challenger 6.1L as my vehicle. Am I over looking it?
Kahler
Post by Kahler »
Ok, Im back here for info. Left for 3 days, accedintly left hooked up and batt DEAD. Do we have a download fix yet that works ?
change sleep monitoring to 30 seconds.
