abs light and Brake light go on with stock tires.
grahamce
Post by grahamce »
I have a Trinity T-1000.
2007 GMC GMT-900 Sierra 4x4 w/ 5.3L
I searched the forums, and this seems to be a common problem.
When I load either the diablo tune, or the 87 octane tune my ABS light and Brake light (!) goes on. I run stock tires (265/70 17). The stock tune does not cause this issue.
I have tried to manually set the tire size in the tuner to the proper size and the lights will go on even sooner then if I hadn't entered the tire size at all.
I have the latest update v.1r07e.
Is there a fix for this?
Diablo retailer website stated the Trinity has TCM support for a 2007 gmt-900 GMC Sierra 1500 4x4.....
RE: abs light and Brake light go on with stock tires.
so, you are not adjustng anything in the tire size or gear ratio settings, correct?
grahamce
Re: RE: abs light and Brake light go on with stock tires.
Post by grahamce »
Correct. I do not adjust anything, just load the tune provided. The abs light and brake light goes on in about 3-4 hours of driving.
Both 87 octane tune, and Diablo tune cause the lights to go on. Stock tune does not have this problem.
When I do adjust the tire size, the abs light goes on after about 1-2 minutes of driving.
mikel wrote:so, you are not adjustng anything in the tire size or gear ratio settings, correct?
RE: Re: RE: abs light and Brake light go on with stock tires
can you post the last tune written and original backup please?
grahamce
Re: RE: Re: RE: abs light and Brake light go on with stock t
Post by grahamce »
mikel wrote:can you post the last tune written and original backup please?
GMC 1500 Sierra.grg
Stock tune
(54.95 KiB) Downloaded 200 times
PCM_614088616011.grg
Diablo Tune
(55.37 KiB) Downloaded 157 times
johan
Post by johan »
Both of those files looked stock, attached here are redone files , please let me know if either throw the abs light for you.
I made you 93 and 87 just in case.
pcm_614088616011_perf87.grg
(46.86 KiB) Downloaded 196 times
pcm_614088616011_perf.grg
(46.8 KiB) Downloaded 177 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
grahamce
Post by grahamce »
johan wrote:Both of those files looked stock, attached here are redone files , please let me know if either throw the abs light for you.
I loaded the modified 93 tune and the ABS light and brake light are still going on.
The new tune caused the lights to go on after about 3 minutes of driving.
The default diablo 93 tune takes about 15 minutes now to trip the ABS and brake lights.
The stock tune does not trip the ABS/Brake lights (I just double checked)
grahamce
Post by grahamce »
Hi Mike.
As per our conversation.
Attached is the default diablo 93 tune with the adjustment I made for 265 70/17 tires.
When I entered this tune, my brake pedal started to vibrate, I couldn't stop quickly and rolled past the stop sign. Just a heads up.
PCM_614088616011_Diablo_Tune_modified.grg
(4.25 KiB) Downloaded 184 times
mitties
Post by mitties »
I had same problem with the same truck except with the predator tuner. Only thing I modified in the tune was I turned DOD off and set speed limiter 1 to 120 mph and my abs and brake lights haven't came on since.
Return to “Trinity GM Gas”
