2010 Ram Hemi Tranny Jumping And Rough
08WhiteRam
Ramathorne
Ramathorne
Ramathorne
can you guys post up your last tune written please?
ok sorry i read up on your website i think i got it.
The biggest issue is the slipping feeling as if it cant find the gear so it just shakes and jumps until i let off the gas then hit it again.
I am also having a problem with the idle. I adjusted with all the parameters of it. The drive w/o overdrive is the one with the issue. I increased it 150. But when i come to a stop my idle drops down to about 475-500 and seems as if it is going to stall. If i touch the gas the truck goes back to the idle i want it to be which is about 650 or so. This dont seem normal either. Please look into this also. Thank you guys.
LOL and lastly is there anyway to get the shifting a little firmer. I have 1-2 set to 5950 and the rev limiter in drive to +600 and it seems as if it takes a little to long to shift and not very firm. I hope I don't seem a pain, but I would like it to be firmer and quicker lol.
Thank you
Thank you
- last tune written 10-29-10 PCM_68059436AB_Perf_93oct_modified.drg
- (4.25 KiB) Downloaded 211 times
Im having the same problem. On the highway I'll accellerate hard and the trans will downshift to second gear and it will buck as if the transmission was slipping. I'll let off and it goes away. Almost seems like a lock up issue? Not sure but Im worried its gonna f up my tranny. Performance overall with the latest update is great as far as power, but this trans thing is worrying me. I'll try and post last tune.
2009 Dodge Ram 1500/Quad Cab. Predator Tuner, Volant CAI, Magnaflow Exhaust, Transmission Line pressure booster, Transgo reprogramming kitm ...and hopefully alot more to come!
Same sort of thing here. Doesn't do it all the time, but I've experienced the shaking thing at least twice since updating to 9r09
The worst case was starting somewhere around 40mph, medium-high rpm (3k-4k or so, wasn't watching the tach), stepped on the accelerator, truck shook somewhat violently for a couple seconds before shifting, and then stopped shaking.
Second time was less severe- starting from a more normal cruise rpm (2k or lower), stepped on the gas, truck shook, let off the gas and reapplied, and the shaking went away.
Last tune written along with a datalog from today are posted below. Not sure if the log will help- I tried to reproduce the shaking, but didn't get the shaking quite as definitively as the other times.
- PCM_68059434AB_Perf_93oct_modified.drg
- Last Tune Written
- (4.25 KiB) Downloaded 177 times
See if this helps at all, please let us know.blazingzz wrote:ok sorry i read up on your website i think i got it.
Thank you
- last_tune_written_10_29_10_pcm_68059436ab_perf_93oct_modified_001.drg
- (86.64 KiB) Downloaded 234 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
See if this one helps for you as well and please let us know.09Laramie wrote:Same sort of thing here. Doesn't do it all the time, but I've experienced the shaking thing at least twice since updating to 9r09
- pcm_68059434ab_perf_93oct_modified_001.drg
- (86.66 KiB) Downloaded 203 times
Diablosport INC
Diablosport INC
juankatrina
juankatrina
