LS2 Fuel Pump Duty Cycle 99.6%
Jruss
Post by Jruss »
The Fuel Pump Duty Cycle on my C6 LS2 is always at 99.6%.
Idle to wide open!
I was of the opinion this varied with throttle position.
Is this what I should be seeing?
No codes and engine runns great.
2006 Victory Red 3LT A6, Magnetic Ride, Corsa Sports and Hall Tech Stinger.
Jruss
RE: LS2 Fuel Pump Duty Cycle 99.6%
Post by Jruss »
Is this a normal reading with the DiabloSport on a LS2 engine?
thats not the diablo, thats what the PCM is reporting.
Jruss
Post by Jruss »
Right Mike, but is this what I should be seeing.
No where in the Corvette service manual or the Diagnostics do I see any referral to Fuel Pump Duty Cycle %.
yeah, he's not questioning the predator data... he's wondering if the fuel pump on his car should be at 99.6% duty cycle all the time... or if there's something wrong with the pump maybe??
not sure about that....
Rnhall
Post by Rnhall »
Since it appears NO one is up to speed on this, I will try to make a run this weekend and log my Fuel Pump Duty Cycle.
If I do, I'll let you know the results. :roll:
Jruss
Post by Jruss »
Still watching for results!!! :(
hey Jim, try posting over in corvetteforum.com....
I'd tend to think tho, since you have no issues whatsoever, that it's normal for your car...
Return to “Predator GM Gas”
