2010 Ram Hemi Tranny Jumping And Rough
juankatrina
Post by juankatrina »
ok how and do I get that tune file from my tuner? What does it consist of? Not sure exactly what you mean or how to get it.
blazingzz
Post by blazingzz »
What is the proper way to add it to the tuner. Do you take the truck back to stock and then do a tool update or do i add tune file to the tool. Thank you Johnan
My truck is in the shop now getting new seat covers per some recall and they are inspecting my lift but I will get it back Thursday night. I will download it and drive it Friday and this weekend I will keep you posted on how it is acting. Thank you
Just curious what did you focus on with this change. The tranny jumping. Did youlook at the idle issue or shift firmness. Thanks Johan
09Laramie
Post by 09Laramie »
johan wrote:See if this one helps for you as well and please let us know.
Thank you for checking this out. Will test it out tomorrow morning and try to post again with results asap.
juankatrina wrote:ok how and do I get that tune file from my tuner? What does it consist of? Not sure exactly what you mean or how to get it.
Downloading tunes from the tool
blazingzz wrote:What is the proper way to add it to the tuner. Do you take the truck back to stock and then do a tool update or do i add tune file to the tool.
Sending custom tune to tool
Found both of those documents, and some other interesting info on the Support Documentation page.
johan
Post by johan »
He he, thank you ^^
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
juankatrina
2009 Ram Hemi Tranny Jumping and Rough
Johan,
Here is my last tune that I installed that is causing tranny being rough and shaking at WOT @ 40-55 mph.
PCM_68059436AB_Perf_93oct_modified.drg
(4.25 KiB) Downloaded 219 times
juankatrina
RE: 2009 Ram Hemi Tranny Jumping and Rough
Johan,
Hopefully you can have tune back to me before weekend so I can give it a try.
09Laramie
Post by 09Laramie »
Tried the tune this morning- didn't experience any of the shaking that I described before. Also seemed a bit smoother in general when accelerating from low rpms without the transmission downshifting.
I'll keep monitoring it and let you know if the shaking comes back.
Thanks again
johan
Re: RE: 2009 Ram Hemi Tranny Jumping and Rough
Post by johan »
juankatrina wrote:Johan,
Here you go, please let us know asap so we can make an update for this.
pcm_68059436ab_perf_93oct_modified_001.drg
(86.62 KiB) Downloaded 248 times
Diablosport INC
blazingzz
RE: Re: RE: 2009 Ram Hemi Tranny Jumping and Rough
Post by blazingzz »
I will not be able to try the new tune out till Saturday, the dealer is not done with it yet. I will try it out this weekend and I will let you know how everything is Monday thank you Johan.
johan
Post by johan »
Ok cool cool, i have a wrangler update i am holding up for this so the sooner the better, trying to make everyone happy :)
Diablosport INC
juankatrina
johan,
I installed the tune and I still have the shaking at WOT @ 40 to 55 mph. So its still having problem. The shift points seem quicker also between shifts but not as firm as before. Any more ideas what it could be? I also modified the paramathers on this tune. Could modifying your tune keep causing it, or should I just try your tune as it is?
johan
Post by johan »
What parameters did you modify? And i would suggest trying to run the tune without the parameters modified just to check.
Diablosport INC
juankatrina
I also over weekend tried with changing parameters and still having same problem. The parameters I changed at first was the throttle sen to 20%, shift points 1-2 to 6000, 3-4 to 6100 & rpms in drive to plus 600. So I tried them both and no change.
juankatrina
Over weekend I tried without changing parameters and still same problem. Just had to clarify my last post.
johan
Post by johan »
Are you sure you loaded the tune in properly? I saw you posted some questions on how to so i have to ask.
Diablosport INC
