VEHICLE NOT SUPPORTED???
callbeckd
Post by callbeckd »
2006 DODGE CUMMINS 5.9L
Just upoaded the newest revision to trinity for dodge (u7131). Installed back in truck and now it says vehicle not supported when trying to send tune. It reads data and display functions all work. Also will not let me restore original backup. It worked before installing the update. Vehicle runs fine.
callbeckd
RE: VEHICLE NOT SUPPORTED???
Post by callbeckd »
Now it is telling me that the tool is not liscened for this vehicle? It was previously installed in THIS vehicle before the update?!?
Did you not restore the stock tune to the vehicle prior to updating it?
callbeckd
Post by callbeckd »
Yes the stock tune was put back on. If I go under options it says last tune writin was the original backup.
what is the calid, and the revision?
callbeckd
Post by callbeckd »
All it says is - CAL ID : VIN : - with no other info. Version V.1r07a
matt.mccoy25
2006 not supported.
Post by matt.mccoy25 »
I am having the same issues. I havent had my programmer plugged in for a little while. Now, all of a sudden it wont let me monitor the boost guage, or retune the truck. I even tried to restore the original backup under the options menu. I have the latest version off your website as of about two months ago. Either way, that shouldnt prevent me from trying to change tunes. I tell ya that smarty is starting to look a little better all the time. I hope you guys get back to us soon on this issue. I did send your tech dept an email about this.
Matt McCoy
RE: 2006 not supported.
Can you confirm the connector on the bottom of the unit is properly seated in the receptacle?
callbeckd
Post by callbeckd »
I have check and cleaned the connector and even used a new OBD cord and still have the same problem.
Can you give us a call with the tool powered up in the truck so we can try to figure this out?
callbeckd
Post by callbeckd »
Do you have an extension to dial?
pbgooder
Post by pbgooder »
wow, ok all this talk is starting to worry me. I have a 2003 Dodge with a 5.9 cumm. I just got my Trinity in the mail today and while trying to install the tunes, it tells me my vehicle is not supported, cal ID 12235033AK. what the hack does this mean????
pbgooder
Thats an odd calid, can you double check that?
pbgooder
Post by pbgooder »
I did it three times last night ask with the same, away from home now can't recheck again til tonight. What does this code mean?
pbgooder
pbgooder
Post by pbgooder »
Ok just checked it again. States vehicle is not in data base. Tool program is u7130. Confirmed cal id # 12235033AK. Please help. I bought this this thing for a trip and I'm leaving tomorrow afternoon.
pbgooder
