2006 dodge with predator stacked with power puck.
xcentric
Post by xcentric »
Truck used to run fine but recently with the puck installed the truck will just die and crank. When it does start it is full tbhrottle and must be shut off. If it sits a while it will start ok again. With only the predator installed it runs fine. Any suggestions what is going on to make the predator and puck not work well together. In the past all was fine.
RE: 2006 dodge with predator stacked with power puck.
Check the connector on the puck harness for corrosion.
