Chech Engine light on ?
I just purchesed a 2003 F250 with a 7.3ltr motor, It already had the Diablo U7170 installed in it, It was set to the 100+ performance, All worked well and ran great, I re-set it to the 85 setting for fuel economey, Once I started down the road, the check engine light came on, The only thing I had changed was the Diablo setting, So I set it back to the 100+ setting, and the light went out, Do I need to change or do something different to the diablo setting when going to the 85 econo setting ? nothing is wrong with the truck, just the check enging light
RE: Chech Engine light on ?
Did you read the codes? If so what is the code/s?
http://www.tpctuning.com
When I pulled it up it said P0602, P0605, P1211 and P1690 are normal for tuned, and it came up with a P0603 which say's PowerTran control module Keep Alive Memory (KAM), I've cleared the KAM but it cames back, Do I have to worry about this and is it OK to run with the "Service Engine Light" on Sorry, But I'm new at the Diablo programer
Post your original backup and last tune written with both the 85hp and the 100+hp files. I will take a look.
Troy07Diesel
You will need a custom tune to keep the light off.
Troy07Diesel
How much would a custom tune cost? Also, right now the predator has the tow, economy, and performance tunes. Would I need to get a custom tune for each one if I want the light to be off? I manly use the performance tune though. By the way, do I have to worry about anything else on the truck like injectors and that when I'm running these tunes? Thank you.
Yes you would need a tune for each level you would want to use. Contact us via email in the signature below and we can go from there.
Troy07Diesel
Everything is done via email. Real simple process.
