Says Last Tune Did Not Finish
It says last tune did not finish and wants to restore original back up. But it will not restore back up tune. Then wants to reboot. Thats all it will do any ideas
RE: Says Last Tune Did Not Finish
Might be good to post what vehicle, what Predator, revision, etc....so someone can respond intelligently.
How did this happen?
Did you get it used like this?
Were you trying to install a tune and it got unplugged?
I've been having problems since I had to replace my APPS on my 03 with U7130. The new APPS cured all the previous problems with codes so I tried to load a tune and it said it didn't go in. The tool said to disconnect the batteries and try again. I tried again and it still wouldn't go in. Then it tols me to load the stock tune and it took about 3 tries to get the stock tune to load. Tech support said I need to update the rev in the tool and now I'm having problems with that. I DL'd the latest rev but the DSDL can't find it. Craig
03, HO, 6sp, 4.10, Predator, A2k turbo, GDP 391, Dual BHAF's, 4" exhaust.
If dsdl cant find it, it indicates you need to load the USB to serial driver for the cable.
