2008 silverado brake and abs light comes on
black03silverado
Post by black03silverado »
just installed the 87 octane tune, turned off the active fuel management(DOD) and adjusted the tire size to 285/70-17 on my 2008 silverado 5.3, now when i drive a couple of miles the brake and ABS lights come on when i shut the truck off for a bit they will go out, but come on once again after a couple of miles driving , how do i get them out??. other mods i have done to the truck are a k and n drop in filter and magnaflow cat back exhaust, the tuner i used is the U7194. the version i think was v9r18, the truck is a 2008 chevrolet silverado 5.3l flex fuel and it is 4wd. thanks
RE: 2008 silverado brake and abs light comes on
Try lowering the aspect ratio setting to 65, and see if that helps.
mitties
Post by mitties »
Try setting speed limiter 1 to 120mph and don't touch speed limiter 2. This worked for my truck 07 5.3 4x4.
black03silverado
ok changed tire size aspect to 65 and set limiter1 to 120 mph took for a drive seems ok , going on a longer run tomorrow will keep u posted!!
That thing must haul ass. You were going pretty fast when I passed you.
black03silverado
ok went for a longer drive today everything is great!!!!! thanks for the help guys!!!!!!!
cool... ;)
black03silverado
Re: RE: 2008 silverado brake and abs light comes on
06MonteSS wrote:cool... ;)
more like AMAZING!!!!!! what a difference in my truck!!!!!!!!!
black03silverado
black03silverado
RE: Re: RE: 2008 silverado brake and abs light comes on
this fixes the e-brake and abs light problem on the nnbs gm trucks or atleast it worked for mine!!
awesome, glad you are enjoying it.
