Let us know your current problems with your 6.4 U7164
diablojesse
Post by diablojesse »
Having problems with your 6.4 U7164?? Post up your current problem(s) and make sure to include the CALID and revision or we will not be able to correct any issues.
- Jesse
DiabloSport, Inc.
561.908.0040
travislbennett
RE: Let us know your current problems with your 6.4 U7164
Post by travislbennett »
Heres my problem. It doesn't do what it is advertised to do.
1. I can not adjust the tire size for my 35 inch tires.
2. I tried the Tire Revs adjustment but that doesn't work either.
3. I have ran 2 tanks of diesel on every tune and the Mileage gains that are advertised just aren't there. I have gone back to the stock tune to get the best mileage. best I had with the 7164 was 10.9, I am at 12.4 with the stock tune.
4. Customer service is poor at best.
travislbennett
Exactly the response I expected
Dawgman
Post by Dawgman »
Travis,
Let's give Jesse a chance....Looks like he's new and wants to help some of ya'll that have had some real troubles. I just want more MPG's before we get up to $5 per gallon again...or even 4 for that matter. :?
Re: RE: Let us know your current problems with your 6.4 U716
travislbennett wrote:Exactly the response I expected
What do you mean?
Can you give us your calids as Jesse asked in the first post, so we can try to help?
Dawgman wrote:Travis,
She ;)
travislbennett
What do you mean?
I mean there is usually no response. Here are my cal ids along with my original post
Version 9r12a
Unit 1 8u7a-14c204-cf
Unit 2 7u7a-14c337-ab
RE: Re: RE: Let us know your current problems with your 6.4
Thanks for adding the cals, that will help.
MikeP5569
Problems with Predator U7164
Post by MikeP5569 »
I have been running the 80hp tune for 2 months and had a problem with the exhaust filter cleaning cycle. My truck was stuck on the exhaust cleaning for 2 1/2 days (I drive roughly 50-75 highway miles in a day) until I installed the original back up and the problem was gone. I have not since re installed the predator in my truck, nor had any other related problems. I do not see any mileage increase on any of the predator tunes. This device may be justified if it, at least had a DPF delete function.
Part#U7164
Revision-u7164-9r12a.crom2009
Ford F250 Superduty
Cal ID
Unit 1--8C3A-14C204-YE
Unit 2--8C3A-14C337-DB
diablojesse
RE: Problems with Predator U7164
MikeP, please post your calids
- Jesse
DiabloSport, Inc.
561.908.0040
Randylic
Post by Randylic »
Hi All;
I just registered, after purchasing a Predator U7164. I have not installed the tune yet but have my doubts about it's quality, judging by the previous post on this forum. Is there anything I need to know before installing the tune to get better milage on my Ford?
travislbennett
What do you mean?
Version 9r12a
Anything Jesse?
The point of this thread is to gather info from users to see what specifically needs to be addressed, so we can make sure that gets done during the current update that we are working on.
Andysapp
Post by Andysapp »
Post subject: 2008 Ford F250 King Ranch 6.4L- unable to change tire size Posted: Jan 24, 2010 - 07:52 PM
Hi. I have a 2008 Ford King Ranch F250 with 20" tires and have installed 17" winter tires (winter tires are not available in original size). I have tried changing the tire size several different ways (even reverting back to the original tune and going to 900 revs down to 550 revs) and the Predator U7164 shows the change but the speedometer error doesn't change at all. I have even downloaded the latest crom with no change. You did indicate that the problem may be that the Predator isn't writing to the ABS module. Any idea when I might be able to look at my speedometer and see the right speed?
unit 1: 8U7A-14C204-CF
unit 2: 7U7A-14C337-AB
email [email protected].
Thanks, Andy.
As you can see I have had issues for a while. If you follow my original post you will get some idea of the problems encountered.
Bottom line : 1)ability to change tire sizes.
2)better fuel economy (would depowering the tune help with this as I don't generally need all the power this truck has on a daily basis?)
3)biggest issue with some of the tunes is too long a DPF regen or an inability to get out of a regen once initiated.
Does this help?
Yes, thats great feedback, thanks Andy.
Are you running the latest revision?
