up graded 7146 to 9r09, no 91 octane tune?
tsbman
Post by tsbman »
All I got was the 87 octane tune and the 93 octane tune. Isn't it supposed to come with a 91 octane tune? 93 octane isn't available here in Utah.
Troy
Shaken
RE: up graded 7146 to 9r09, no 91 octane tune?
Post by Shaken »
I am pretty sure you need to remove 2 degrees from the wide open throttle timing menu which I believe is in percentages no degrees.
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
Return to “Predator Ford Gas”
