New U7194 update, new tunes!
RE: Re: RE: Custom tune Have Volant CAI and Corsa sport cat
NICE!! :)
enjoy man!
TexAg
Post by TexAg »
I just got the Diablo tune installed on my 2011 Silverado. My primary reason for getting the Diablo is for improved fuel efficiency. That being said, which tune should I run? The guy at the shop said the 87 octane tune is primarily for users in the northern part of the country. Not sure what he meant by that. I would rather not have to pay for premium gas.
Thanks!
2010gmc
Post by 2010gmc »
I put the 87 tune in my truck and was geting 18.9 before and after tune i get 20.1 even running hard.I love the thing,good luck.
Michigander
2010 gmc 1500 119 wheel base 2wd
reg cab short bed in other words
5.3l 6 speed 3.43
Custom series 40 1 into 2 exhaust
Volant CAI
built in Fort Wayne
I really dont hall nothin but ass...
TexAg
Post by TexAg »
Are the harder shifts going to be harder on the tranny and rear end? I had the back end get loose shifting into 2nd and 3rd. I love it, just want to make sure I'm not going to tear anything up.
2011 Chevy Silverado Texas Edition crewcab, K&N cai, Magnaflow exhaust, Diablo Sport Predator tune, spray in bedliner
mudder100
RE: Re: New Tunes
Post by mudder100 »
will this update help my 4.8 or is it for 5.3 only?
Re: RE: Re: New Tunes
mudder100 wrote:will this update help my 4.8 or is it for 5.3 only?
you need to get your other issues straightened out first...
try putting a battery charger on your battery when you try to tune the truck man...
jrodela06
RE: Re: RE: Re: New Tunes
Post by jrodela06 »
i just updated my u7194 to 9r20 and I tried to install it into my 2008 Silverado 5.3 non flexfuel and it said original backup not saved(-11) and it gave a reduce engine power in the instrument cluster with a few codes: p0606, p0607, u0101, u0109, u0121, u0140 and another immobilizer code. it was working fine before with one of the previous updates. please email:: [email protected]
thank you.
bocass
Post by bocass »
I am having the same issue as jrodela06 on my 2010 Camaro SS. try to install Diablo tune and it throws stablitrack error and loads the codes listed in his post. Car wont start until i clear codes.
I was on V 9.14 this morning and it worked fine.
jrodela06
Post by jrodela06 »
^still have not got a correct fix from diablosport as of Thursday I was told to disconnect battery and try again, that failed so I downgraded to 9r19 and it worked like a charm.
bocass
Re: RE: Re: RE: Re: New Tunes
Post by bocass »
jrodela06 wrote:^still have not got a correct fix from diablosport as of Thursday I was told to disconnect battery and try again, that failed so I downgraded to 9r19 and it worked like a charm.
Ill give that a try. thanks for the info. I tried to go to 18 and it wouldnt let me.
bocass
RE: Re: RE: Re: RE: Re: New Tunes
Post by bocass »
Downgrade to 9r19 worked perfect. Phone support wanted me to send it back to them. Told me that device isnt meant for downgrading??? Just an image thats flashed. Since a few of us are having this issue and my predator is only a year old i suspect they have an issue with 9R20...
Thanks again jrodela06 for the info.
bocass
Re: RE: Re: RE: Re: RE: Re: New Tunes
Post by bocass »
bocass wrote:Downgrade to 9r19 worked perfect. Phone support wanted me to send it back to them. Told me that device isnt meant for downgrading??? Just an image thats flashed. Since a few of us are having this issue and my predator is only a year old i suspect they have an issue with 9R20...
Any coments from tech support on this?
Here you go guys, this is the fix for this issue.
u7194-9t21b.crom
(1.41 MiB) Downloaded 169 times
sonic13
Post by sonic13 »
mikel wrote:Here you go guys, this is the fix for this issue.
is this a fixed version 20 or a faked version 19 just to get the predator downgraded to a working version?
hahaha... fixed 9r20....
