2006 mustang Gt starting issue
st577
Post by st577 »
2006 Mustang Gt, Predator U7140, V.9r04 Univ_Rev
I went from using 87 performance tune to firm shift 93 octane then back.
Now when I start the car it will not idle unless I give it gas on startup. It revs then stalls. I have mod parameters 3.73 gears, K&N fipk, 800 rpm neutral, 800 rpm drive, traction control off.
I had changed the tune to run at Bradenton now need it changed back to daily driving.
car will drive and idle but not at what I have it set at any suggestions?
Thanks Mike
RE: 2006 mustang Gt starting issue
Try the K&N tune...
st577
Post by st577 »
went back to original backup and seems to have corrected itself, will try going back to a different tune in a few days, thanks. Mike
st577
Post by st577 »
well it was short lived, changed back to 87 tune still has start stall issue, went back to stock and get limp mode, tried several tunes all have start stall issue, I had changed the plugs to autolites, and then had start stall issue My guess is I need to look for a vacuum leak.
st577
Post by st577 »
ok I got the original backup working ok car starts and idles, but I have 3.73 gears and if I modify the tune I get the wrench. What could be the problem. Car will not start and idle any longer with the canned tunes. the only change I made was autolite sparkplugs?
sounds like a non tune related issue
st577
Post by st577 »
why would the rpm change in the modify tune not take? how can I remedy this?
st577
Post by st577 »
Problem solved removed and cleaned throttle body had dirt around the butterfly's choking it out, no problem with start and now idles where i program it.....
Return to “Predator Ford Gas”
