Smooth MDS and Increase Throttle Response
adbutz
Post by adbutz »
Hey Mikel can you Smooth the MDS surge and Increase throttle response for the 91 octane cai tune. Its my last written and I attached it.
If possible could you do the same for my original back up
I have U7135 with the last crom update(9r28)
My car is a 2009 Dodge Charger with the 5.7L engine
Aaron
Last Tune Written.drg
Last Tune Written
(3.25 KiB) Downloaded 218 times
Original Back Up.drg
Original Back Up
(88.17 KiB) Downloaded 191 times
adbutz
RE: Smooth MDS and Increase Throttle Response
Post by adbutz »
Hello
I'm just wondering if I could get that MDS smoothing tune for the above files.
Aaron
here you go
last_tune_written_smooth.drg
(74.31 KiB) Downloaded 296 times
adbutz
Post by adbutz »
Thanks. Do I have to re-install the original back-up before I download and install this tune
No...
adbutz
Post by adbutz »
perfect, thanks again
If you update to the latest revision, you can adjust the throttle sensitivity yourself.
adbutz
Post by adbutz »
Hey Mikel, just a quick question on this tune. When you send the tune back with the smooth, is it still a 91 cai tune or should it be considered a whole new tune in itself. The only reason I ask is because finally the roads were dry and ready for some 0-60 times. When I attempted them, I was actually getting worse times than without the predator. Before the predator(stock), I was getting 0-60 times of around 5.5 seconds but with this tune I have yet to get under 6 seconds. Would running the 91 cai tune without the smooth be any better. I purchased this unit to get better times not worse. On a brighter note, the everyday driving with the smooth is much better, ie less drone/stutter when mds kicks in and for this I am grateful. But I would like to push this car to the low 5 second mark if possible. Thanks Aaron
yes, same tune you posted just with the smoothing applied.
worlthompson
Post by worlthompson »
Mike What did you adjust on the tune to smooth out the MDS???
WKgrand08
Post by WKgrand08 »
I am curious as well since I am experiencing the same on my end.
worlthompson wrote:Mike What did you adjust on the tune to smooth out the MDS???
you can compare the files and see ;)
simple timing change...
frankiek
Post by frankiek »
I would pull the F2 fuse for a couple of minutes, the adaptives may be hindering you. My 09 Rt runs consistently in the 5.1 range with the 91cai tune. Fastest has been 5.0, I dont think its the tune.
dnar
Post by dnar »
Hi Mike,
How about sharing the details with us please?
adbutz
Post by adbutz »
Hey mikel, I was on hypertechs web page and they had an interesting way of controlling the mds. Their tuner could be programed to deactivate mds below a certain speed which the owner could choose. I was curious if diablo's working on something similar, or if something like that is being discussed, as this would be one way of getting good mileage on the highway, while not having that pesky drone while in town. Aaron
