Diablosport Extreme Puck P2020
2006 Duramax with LLY engine.
Guys I have 3 questions:
I am setting a P0087 code when using the puck, why is this?
What is the towing capacity using the puck?
If the knob is turned all the way down is it at stock settings for the truck,
and what HP and TQ does the puck add turned all the way up. This is not mentioned anywhere i can find.
2006 Duramax - P0087 Code Set
Nobody here can help me?
Surely someone here can answer my questions! I really
could use some help on this, Thanks
RE: Nobody here can help me?
It will add up to 30% power increase when the knob is turned up all the way.
Towing capacity is as much as stock can support.
The code sounds like you maybe did not install the shim kit or did not torque it down all the way...
