Hey guys,
I did some pulls on a Dyno months ago and I used Dataviewer 3.2.0.7 to download the logs from the Dyno pulls I did. Well the logs looked fine and I could see the logs and the Analog input for my Wideband that i am logging. well I wanted to go back to see the logs and have found that the log has no wideband input on it now and I am using dataviewer 3.3.0.7. I also exported a CSV file and I do nt see the wideband on there any more as well. So in order for me to see it I wil have to go back to Dataviewer 3.2.0.7, but is there any easier way to do this other then removing a Dataviewer 3.3.0.7 and installing 3.2.07?
Thanks!!!
Below is the log of a Dyno Pull I downloaded using Dataviewer 3.2.0.7
I lost my Analog input in Data Viewer 3.3.0.7
RE: I lost my Analog input in Data Viewer 3.3.0.7
The older 3.2.0.7 can be downloaded from here: http://www.diablosport.com/CMR/software ... .2.0.7.exe. It's no longer supported and should ONLY be used for viewing logs recorded with older Trinity CROMs. It does not do live streaming and does not work with DCX_CAN_GAS Croms.
When you install it, specify a different destination folder than the one 3.3.0.7 resides in. You can have them both co-exist on you PC/Laptop provided the executable live in separate "Program Files" folders. Also, un-select the create Desktop and Task Bar Icons in the installer dialog otherwise it will point the shortcut Icons to the older version. Create your own shortcut and name it "DataViewer3207" or whatever you like.
Re: RE: I lost my Analog input in Data Viewer 3.3.0.7
Thanks Jim you are the man!!!! Will do what you describe above.....jimb wrote:The older 3.2.0.7 can be downloaded from here: http://www.diablosport.com/CMR/software ... .2.0.7.exe. It's no longer supported and should ONLY be used for viewing logs recorded with older Trinity CROMs. It does not do live streaming and does not work with DCX_CAN_GAS Croms.
