2006 Jeep SRT8 surging CUTTING OUT MAJOR ISSUE.
tzitzikas
Post by tzitzikas »
2006 jeep srt8 vortech sc 8 psi CMR custom tune. Just purchaced the truck.
The idle will surge up and down when cold then smooth out when it warms up.
Had another tune made, same problem.Installed headers and the problem got worse ! Now it jerks you back and forth between 1000rpm and 2000rpm then stalls out,it feels like ignition.Can barelly drive it now with out cutting out.
Code P108 baro sensor and the P061A throttle torque management.Reset the computer same issue.Checked all the grounds and fuses and traced the ETC and MAP sensor wiring OK.
REPLACED:
PCM REPLACED AND FLASHED WITH THE LATEST UPDATE -IGNITION COILS-THROTTLE BODY-CRANK AND CAM SENSORS and new MAP srt4 sensor.New Pcv valve and ngk plugs. Dynoed at 475 at the wheels fuel and timing is good.
Replaced the intake gaskets.Stock tune flashed same issue.Only 37000 miles.
RE: 2006 Jeep SRT8 surging CUTTING OUT MAJOR ISSUE.
Have you asked the tuner to check it out?
Has he reviewed logs of the vehicle surging?
tzitzikas
Re: RE: 2006 Jeep SRT8 surging CUTTING OUT MAJOR ISSUE.
Post by tzitzikas »
mikel wrote:Have you asked the tuner to check it out?
Yes the logs showed the TPS ETC voltage is surging up and down.The only thing that comes in my mind now is the electric gas pedal is the only thing i have not replaced.The tune is good.Its getting worse by the day now. what id did notice on the logs is the tps is fluctuating at idle. So now i will replace the gas pedal.
RE: Re: RE: 2006 Jeep SRT8 surging CUTTING OUT MAJOR ISSUE.
Its not that.
Timing is most likely causing the surge, and it should be apparent in the log files ;)
tzitzikas
Re: RE: Re: RE: 2006 Jeep SRT8 surging CUTTING OUT MAJOR ISS
Post by tzitzikas »
mikel wrote:Its not that.
The idle does not surge when it is warmed up.It is good.
It is hesitating a soon as you feather touch the gas pedal and then stalls out, timing is 11 to 19 at idle fluating, when you touch the gas pedal goes to 29.
RE: Re: RE: Re: RE: 2006 Jeep SRT8 surging CUTTING OUT MAJOR
post it up.
tzitzikas
Re: RE: Re: RE: Re: RE: 2006 Jeep SRT8 surging CUTTING OUT M
Post by tzitzikas »
OK
RE: Re: RE: Re: RE: Re: RE: 2006 Jeep SRT8 surging CUTTING O
where did this tune come from?
MHP?
tzitzikas
Re: RE: Re: RE: Re: RE: Re: RE: 2006 Jeep SRT8 surging CUTTI
Post by tzitzikas »
mikel wrote:where did this tune come from?
MHP?
B/G chrysler
RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006 Jeep SRT8 surging C
To be honest, you may be better off starting with a new tune.
Check cherokeesrt8.com for some recommendations from the guys there ;)
tzitzikas
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006 Jeep SRT8 surgi
Post by tzitzikas »
mikel wrote:To be honest, you may be better off starting with a new tune.
What is wrong with the tune?
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006 Jeep SRT8 s
What wrong is that B/G is not one of the better tuners out there. In fact, many guys avoid them like the plague.
Where are you located?
tzitzikas
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006 Jeep SR
Post by tzitzikas »
Mike_Levy wrote:What wrong is that B/G is not one of the better tuners out there. In fact, many guys avoid them like the plague.
PA
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006 Jee
If you can come out to Long Island I'd highly recommend having AJ (HemiTuner) at Westbury Jeeps HemiShop do your tune. He among the best in the world and many, many of us swear by him.
tzitzikas
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: 2006
Post by tzitzikas »
Mike_Levy wrote:If you can come out to Long Island I'd highly recommend having AJ (HemiTuner) at Westbury Jeeps HemiShop do your tune. He among the best in the world and many, many of us swear by him.
What is web link?
Got phone number?
