2004 F650 C7 cat Problems
I have a 04 F650 with a c7 cat . I installed a M2010 , The truck will not go over 45MPH with the puck installed but runs fine without it . There are no check engine lights on . The instructions do not clearly state which plug goes to the map sensor or the fuel sensor . I tried it both was with the same result . , Just a note the wire harness plugs were defiantly used . They were not new . Also with the knob turned all the way to the right the truck will not start . There in nothing I could find in the instructions that even indicated what to do with the knob . It only says to mount it on the dash . I assume turning it clockwise turns up the power is this correct ??
RE: 2004 F650 C7 cat Problems
the middle plug would be fuel and the end plug would be MAP.
What about the knob . Is counter clockwies more power ??
clockwise makes more power, all the way to the left is off.
now the truck will not start with the fuck installed . I just called atech for a rma .
Sorry I ment to say puck . It was a freudient slip .
tjkelly212
got a link to that post?
tjkelly212
Title: "Extreme Power Puck installed on a Cat C7 engine"
https://www.diablosport.com/index.php?n ... ight=m2010
Also in Title: "Wiring instructions for M2010 powerpuck for cat motor" 11/26/2008
MaxDiabloSport says that the blue and white wires go to the fuel pressure sensor. Those are on the end, not the middle.
Again, I just want to get it right the first time so I don't hurt anything.
Thanks in advance for your help.
There are occasionally variations, but it looks like in this case the MAP is in the middle.
you wont hurt anything if its wrong, it just wont start
tjkelly212
yes, clockwise = power.
best mileage gains will be found from playing with the knob with your driving style.
tjkelly212
