vehicle is not in data base??????
i have a 05 3500 ram, ive been using the predator since 08, i tried my buddys smarty out to see how it worked, and when i went to reinstall my predator it came up your vehicle is not in our data base. says my Cal_ID is 25325353AI?? the current version i have is V.9R05 and its a U7130. does anyone kno why this would happen? i have tried other proggramers and let others try mine and never had any issues. if any one could help would be appreciated.
RE: vehicle is not in data base??????
the smarty did put 'your' stock tune back in, it loaded a random update from dodge.
You'll need to update your Predator to the latest revision to support that new calibration.
how do i go about updating, i never recived a cord with my predator?
05 ram 3500 drw, 5" lift, k&n cold air, predator, boost fooler, 4" mbrp, glow shift guages, 37's BFG KM2.
figured it out, gunna try this RKL tune now that i have the kno how
be careful with that rkl tune, unless you have a built trans (or upgraded clutch)
may give me a reason to get a built trans..... just outta curiosity whats the RKL stand for? i assume puff is excess fuel for smoke. and is it jus and extreme tune with added timing or is it a seprate tune all together? jus dont wanna hurt the engine if i run it for a duration of time
