NEED HELP ASAP!!!! Updated Predetor NOW problems
I NEED Help ASAP!!!! I just tried to update to 29 File and now It reads "" Incompatible Hardware. ( No Serial Flash Found. ) Contact Tech Support. WHAT DO I DO??????????? My car has to have my custom tune to run!!!!!!!!!!
RE: NEED HELP ASAP!!!! Updated Predetor NOW problems
The Predator is one of the older ones with limited memory. Need more info on your car. If its an 05-08 reinstall 9r12. Thats the latest version that can be used with the older Predators and older cars. If its an 09-10 you can use the Limited CROM. I attached it below.
- u7135_9r29l_170.crom
- 9r29 Limited CROM
- (986.74 KiB) Downloaded 112 times
I have a 2006. I reinstalled the 12. How can I get throttle boost?
unfortunately it is not an option on your older tool.
If you wean to try some TB added to the tune, post up last tune written.
Ok I will post it up. Also I cant get ahold of my tunner, I fixed my Fuel line problem, and now I'm running super fat. Could you take some fuel out of the tune and adjust it.
Here is the Custom Tune. I'm running 11.3 on my Wideband.
- 05030232AF_custom.drg
- (7.25 KiB) Downloaded 115 times
Here you go, there was about 10% throttle booster in the tune already, I added some more
I dont lean out tunes...not a good idea for a car I know nothing about
- 05030232af_custom_booster.drg
- oops...
- (46.91 KiB) Downloaded 118 times
