MEXICO AND DIABLOSPORT.....will it work?
tor-rojo-mx
RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABLOSPORT.....will
is there an ETA on it?
guys... press the RESET and MUSIC Button on your steering for 8 seconds... you will get a new menu on your EVIC Display... the first screen has a CCN Date... although our cars are 2006 models, I think some of the EVIC dates are late 2005... could this be the problem?
Re: RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABLOSPORT.....w
You are right, my SRT8 is 2006 but the EVIC dates are late 2005.coliseum wrote:guys... press the RESET and MUSIC Button on your steering for 8 seconds... you will get a new menu on your EVIC Display... the first screen has a CCN Date... although our cars are 2006 models, I think some of the EVIC dates are late 2005... could this be the problem?
Ahmad
RE: Re: RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABLOSPORT..
So what do we do now?
(twahagna ya rayyal)
it has nothing to do, remember chargers where not made on 2005 models, only 2006 up and where built on late 05 and early 06 check your manufacturing date on the sticker on your drivers door, it will show some date in 05 thats why you have a 05 dated software
now if you have a 2005 300c or magnum dated late 04 then that could be a problem
06 Charger RT
update on export calIDs release please!!!
06 Charger RT
G'day guys.
Please follow these instructions as they may be of assistance.
This will only be applicable to those who have received the update file from Diablo. Anything else please PM me.
Step by Step instructions.
Please uninstall and delete all existing Diablo programs and files.
Please reinstall the most current DS Downloader http://www.diablosport.com/downloads/pr ... .9.6.2.exe
Please copy this file to an easy to locate area on your computer (Your desktop or C:\temp would be best) http://www.diablosport.com/downloads/pr ... 8t16a.crom
1. Please copy and save the updated file from Diablo to an easy to locate area on your computer (Your desktop or C:\temp would be best).
2. Start up DS Downloader
3.Connect Predator to your computer/downloader
4. Under Express Tune Mode click Send CROM file to Predator. Here it will ask you to locate the file you saved prior (8t16a.crom) and update to predator. Ensure that when it is done that this version is shown at the top of the Predator. It will look like this – Predator v.8t16a.
5. Run the Calibration update. This should allow you to do so. This will take around 2-5 minutes (maybe longer depending on connection speed)
6. Take Predator out to your car. Before plugging it in ENSURE EVERYTHING IS TURNED OFF. Radio, interior lights, aircon, anything plugged into cigarette lighters unplugged etc. Ensure wipers are off also.
7. Plug Predator into your car and follow instructions on the screen.
8. Allow Predator to save stock backup tune from your car. Start to finish here may take around 10 minutes. It is normal for headlights to stay on during this process as well as to turn on and off a few times.
9. Once completed it will now ask you to update you Predator from Diablo's website. This is also normal even though you have downloaded 8t16a.crom.
10. Going back to your computer, re connect Predator to your PC & DS Downloader. You now need to update/load the attached file received from Diablo into your Predator. This is file 8t16x.crom. Load this the same way you did step 4. Once download is complete it should now work on your car. (DO NOT USE CALIBRATION UPDATER AGAIN).
11. Connect Predator back into your car and away you go.
Any questions please feel free to contact me.
i havent received anything from diablo
btw im using 8t16a and when installing it on my predator it wont let me update, is it cuz my calID isnt supported yet?
06 Charger RT
It should let you update. Best thing to do is email [email protected] with your CALID and probably build date just to be certain your year vehicle is supported. Hope this helps.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
I still get stuck on step 5... says my CAL is not handled!!!
how can I clear whatever CAL is saved in the Predator??? is that possible? so I can have a fresh start??
AND to add to all this mess, I have a 9hour time difference with Florida!!! Used to live in daytona... come on Boca Raton guys... help me out here!
i sent an email yesterday, it never let me update, first it was the message asking if i was connected to the internet, now im getting a new another message it tells me "an error occurred while trying to retrieve the calibration from the server"
mike if you ever see this why it doesnt let us update the calibration on the predator? as stated on step 5???
My calID is 05187099AD
- diablo error msg.JPG (65.54 KiB) Viewed 3742 times
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABLOSPO
Smoke74, you should be good to go. Follow these instructions:smoke74 wrote:i sent an email yesterday, it never let me update, first it was the message asking if i was connected to the internet, now im getting a new another message it tells me "an error occurred while trying to retrieve the calibration from the server"
Install the 8t16c CROM from u7135-8t16c.
Then go plug into your vehicle and try Performance Tune.
After that, you should not need an update, as your Calibration is already current.
On the side, Christy never received an email from you. No problem, you should be fixed after following the instructions above.
johnc <at> diablosport.com
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABL
Hi John... I tried the above, it is not working for me... any idea why? my cal is 05187100AB
please help!
please help!
