CALID 50325053AB NOT FOUND. 2006 DODGE DIESEL 5.9L
REESER
Post by REESER »
HELP ME OUT PLS. I JUST WENT TO DEALER TODAY TO SEE IF THERE IS ANY UPDATES FOR MY TRUCK AND MINE HAS THE MOST CURRECT UPDATE AS PER THERE SCAN TOOL AND IN THERE SYSTEM. I PERSONALLY TALKED TO THE TECH THERE ABOUT WHAT I WAS DOING AND HE SAID THIS CAL ID HAS BEEN OUT SINCE THE RELEASE OF THE ECM REFLASH RECALL RELEASED IN FEB OF 2010. CAN ANYONE HELP?
Sorry for the delay, the files just became available on Dodges website, this update will work for you.
u7131-9t08a.crom
(1.85 MiB) Downloaded 332 times
REESER
Post by REESER »
OK GOT IT DOWNLOADED, UPDATED, AND PROGRAMMED. THNAKS FOR GETTING SUMTHING OUT FOR ME ON THIS. GOT A QUESTION-- WAS THERE ANY UPDATE TO PROGRAMMING OR JUST CALID'S ADDED. ALSO I PUT IT ON THE TOW SETTING CUS
I AM GOING HUNTING AND GOING TO BE TOWING. HOWEVER IT WAS ABOUT 40DEG THIS MORNING HERE AND COLD START THERE WAS A RUFFNESS TO ENGINE AT IDLE. AFTER BACKING UP FROM DRIVEWAY AND PUTTING IN DRIVE NO MORE RUFFNESS. IT WAS TO ME A INJECTION TIMING TYPE RUFFNESS NOT A INJECTOR STICKING CUS I HAVE HAD THAT HAPPEN AND
WAS NOT LIKE THAT. JUST SUM INFO FOR YOU IF YOU DIDNT KNOW ABOUT IT. IF YOU KNOW OF WHY IT DOES THIS CAN U LET ME KNOW I AM JUST INTERESTED. OTHER THAN THAT FUEL MILAGE UP 3 MPG AND TIRES ARE SMOKIN.
We're still looking to get some new tunes made for these applications, keep an eye out ;)
