using 89 on the 87 octane setting
new here and want to purchase one of your tuners
will running 89 octane hurt anthing when set to 87 tune, will also be using truck for towing which is its primary use.
U7137
truck is a 04 ram 1500 5.7
U7137
Re: using 89 on the 87 octane setting
You will be fine. No problem running an 87 tune on 89 oct. You just can't do it the other way around.maxxguy1 wrote:new here and want to purchase one of your tuners
U7137
RE: Re: using 89 on the 87 octane setting
ok thanks will the program hurt my truck wich has 200000 miles on it. reason asking somebody told me it would blow the engine
Re: RE: Re: using 89 on the 87 octane setting
Who ever told you that has a blown mind. You will be fine as long as you are not haveing any issues before you load the tune. You know a rod knocking ect.maxxguy1 wrote:ok thanks will the program hurt my truck wich has 200000 miles on it. reason asking somebody told me it would blow the engine
Re: RE: using 89 on the 87 octane setting
What is a 98 Hemi Dakota?69rrbruce wrote:Minimum of 87 octane on tune.
bighemitex
i'm betting he might be one of the people who is lucky enough to have a dak with a hemi transplant. it would be sick to have a rcsb dak with a hemi.brandy16 wrote:What is a 98 Hemi Dakota?69rrbruce wrote:Minimum of 87 octane on tune.
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
I did a Hemi swap in my 98 Dakota Sport.....check out my swap thread on Dakota-Durango forum:brandy16 wrote:What is a 98 Hemi Dakota?69rrbruce wrote:Minimum of 87 octane on tune.
http://www.dakota-durango.com/forum/sho ... ostcount=1
98 Hemi Dakota
RE: Re: RE: using 89 on the 87 octane setting
There is not a 87 octane tune (at least named like that) I have read here & there (do a serch on the forum) that the MPG booster tune is actually a 87 octane tune if that is the case (I think that Mikel posed that somewere) you will be fine using 87 fuel with that tune.
bighemitex
Re: RE: Re: RE: using 89 on the 87 octane setting
my predator has a 87 octane tune. Pretty sure that's on all the DSPs for the Ram.abuelo wrote:There is not a 87 octane tune (at least named like that) I have read here & there (do a serch on the forum) that the MPG booster tune is actually a 87 octane tune if that is the case (I think that Mikel posed that somewere) you will be fine using 87 fuel with that tune.
RE: Re: RE: Re: RE: using 89 on the 87 octane setting
ok....then you should be fine ussing that fuel.
I have an 02 dakota 4x4. I was thinking of puting in a 5.7 but was told by some that the 5.7 was to wide to fit.69rrbruce wrote:I did a Hemi swap in my 98 Dakota Sport.....check out my swap thread on Dakota-Durango forum:brandy16 wrote:What is a 98 Hemi Dakota?69rrbruce wrote:Minimum of 87 octane on tune.
