Tranny issues and four diff trouble codes.
my05hammer
Post by my05hammer »
OK where do I start.
1) Predator U7137
2) 9r12
3) 2010 Dodge Ram
4) Transgo shift kit installed in Nov of 2010. (EDIT: Put in correct year)
One month ago I was heading out on a day trip and decided that in order to save a few bucks I put the factory tune back in the truck so I could run cheap gas. The tuner asked if I wanted to "reset all parameters" I like a fool agreed and reset all parameters. All was well for a while, then I noticed that the downshifting of the tranny was harsh or didn't happen at all. When it would act up sometimes it would get stuck in 4th gear and no matter what I did it was stuck in 4th gear. The only way to reset it was to pull over to the side of the road and shut off the truck then restart it, then I got all the gears again. The check engine light comes and goes and has popped up P0734, P0735, P0765, and P0933. All of which are 4th and 5th gear related, pressure related, and solenoid related.
Just a few days ago I tried to updated my Predator from 9r09 to 9r12. The tuner gave me an alarm stating that I could not downgrade from 9r09 to 9r12. This has been taken care of and the tool has been updated to 9r12. So I gathered that there may have been a corrupted file or something? Don't know. So since the tool was updated to 9r12, I reset the truck and put the original tune back in it. This seemed to help and the codes went away. After a few days on the factory tune I installed the mileage tune and now the problem is back. I do not know if it is a Dodge problem or a tuner problem because over the last month since I reset all parameters the problem has reared its ugly head on the factory tune and the Predator tunes.
My point is, is it possible that my Predator is corrupt and needs repaired or replaced? I have an appointment for Friday with the dealer to have the dealer reset the truck to factory tune and investigate the codes. I don't know what to tell them, and I need to know what you guys suggest for the Predator.
Thanks in advance.
white_lightning
RE: Tranny issues and four diff trouble codes.
Post by white_lightning »
sometimes the Predator can corrupt your PCM. sometimes the tuner can have problems. it will be interesting to see what you find out Friday.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
resetting the parameters just undoes any changes that you may have made in the past in the adjustable parameter menu.
You can easily set them back to the way you had them, but there is nothing inthe canned tunes that could/would cause the issues you are describing.
The codes:
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
Are describing a slipping trans, hence the 'incorrect ratio' part.
Not sure how a corrupt file would be to blame, your truck would not run if the calibration files were corrupt ;)
my05hammer
Re: RE: Tranny issues and four diff trouble codes.
mikel wrote:resetting the parameters just undoes any changes that you may have made in the past in the adjustable parameter menu.
The codes:
Cool. That is good to hear. I wasn't sure what the parameters were that were being reset. Thanks for the clarification.
I have loaded the factory tune the truck and I have an appointment with the dealer tomorrow and they are going to check it out and reflash the truck. If it needs a tranny then it needs a tranny, that's what warranty is for. :D
Thanks guys, I will keep you posted as to what they find.
my05hammer
RE: Re: RE: Tranny issues and four diff trouble codes.
It would make sense if it is a bad tranny because ever since it was new, when cruising at 50-60 mph and punching it for a pass the tranny would shutter like a vibrating slipping clutch (when it grabbed 2alt), not like a cycling or hunting problem.
Re: RE: Re: RE: Tranny issues and four diff trouble codes.
my05hammer wrote:It would make sense if it is a bad tranny because ever since it was new, when cruising at 50-60 mph and punching it for a pass the tranny would shutter like a vibrating slipping clutch (when it grabbed 2alt), not like a cycling or hunting problem.
You should share that info with the 09-10 guys who are convinced that the tunes are the cause of that shudder ;)
my05hammer
RE: Re: RE: Re: RE: Tranny issues and four diff trouble code
Well just as I suspected The dealer claims that since I have a CAI, custom exhaust, and have used a Predator that the warranty is now void. They even had the gall to say that the PC in the back seat was a performance part. The darn thing is only for music and hasn't even been hooked up to the stereo yet. I informed them that the Magnison-Morrison act protects me from being denied warranty if the added parts didn't cause the failure. I may have to get a lawyer.
They showed me a list of codes that they pulled from the truck and there were several that were for loss of communication to the tranny, radio, and other stuff. They are in a round about way saying that the tuner has caused these issues. I hardly doubt it since the darn tranny has been slipping when down shifting since I bought it.
Is there any way that I can get a written statement from Diablo stating what the Predator does and that it cannot in any way possible cause the tranny to burn up the clutches?
No, thats not something I can provide, to be honest I might not have said anything about the tuner, as they will ALWAYS blame that no matter what...
my05hammer
I had a dealer tell me that they would be able to tell if a tuner was used or not is this true?
2013 Challenger, 5.7L, 6 speed, Hurst Shifter, 3.92 gear, Jazz Blue with red hood to fender stripes, and Super Track Pack.
my05hammer
I may just return it to stock and take it to another dealer.
my05hammer
Or... I might convert it to a manual. If I convert it to a manual with say a Doug Nash 6 speed, can you guys take the last tune written and modify it so that it will ignore all the auto tranny electronics?
Another dealer is a good idea, as is the manual trans ;)
Should be no prob turning off the TCM, there is a simple switch for it...worst case, send me your PCM I'll flash it with a manual HEMI Ram cal...
my05hammer
Sweet. I will try the other dealer first then start hunting down a manual tranny because the 545's are a pretty poor choice for drag racing anyway.
my05hammer
I have made an apt with another dealer and they know nothing of the tuner issue. If the previous dealer put the report in some sort of corporate system, so what they are the ones who claim that a regular PC sitting in the back seat was the culprit and that is impossible since that PC is not connected to anything. It only has WinXP on it and NOTHING else (it is destined to be part of the sound system for music storage).
I am also now getting a code P0884, something about TCM losing power? That sounds like a complete failure of the TCM or something similar. I will keep you guys posted as to what happens and I will also post up a “how toâ€
chefred112
Post by chefred112 »
sub'd... am curious what your outcome is..have swapped my tranny out several times and can't put a finger on what's causing my issue's...I know the very first time I had one of the original ds's from day one and it caused havoc to alot of tranny's early on which seemed to get fixed with an updated crom at the time...but I'm scared to death to update my tuner now, I'll have to check what the current crom is..
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
