What paramters to set for Long tubes on 07 mustang GT
droptop07
Post by droptop07 »
I am swapping to long tubes and off X x-pipe for now. What parameters need to be adjusted for the long tubes and X-pipe?? How much difference to tune if I swap to catted X-pipe??
I know a dyno tune would be best. But I do have couple other items i want to install beofre final tune, The dyno tunes arent cheap.
RE: What paramters to set for Long tubes on 07 mustang GT
Tough to say what needs to be done without some logs or getting it on a dyno.
droptop07
Re: RE: What paramters to set for Long tubes on 07 mustang G
Post by droptop07 »
mikel wrote:Tough to say what needs to be done without some logs or getting it on a dyno.
Just trying to make it safe to drive until all mods are done. Then plan on dyno tune. Need to read up on the datalogging and see go from there.
bamachips
RE: Re: RE: What paramters to set for Long tubes on 07 musta
Post by bamachips »
The parameters that need to be adjusted are only available in the CMR software and not in the end user options. You will require a custom tune to set this up properly.
Tuning with CMR software since 04' for Ford and since the Dodge CMR was released.
Return to “Predator Ford Gas”
