Low fuel pressure 2006.5?
madmanwithmouse
Post by madmanwithmouse »
I know I saw a topic about this but anyone know what would cause low fuel pressure :? (not rail). I just changed the filther and it helped a little bit. it never gets above 8, and if im on it hard it goes to 0 quickly :o . The sender is in the pump. Im running tow stacker with puck off.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
christina
RE: Low fuel pressure 2006.5?
Post by christina »
How is the pressure with no tune installed??
Christy High
lurker.
madmanwithmouse
Sorry, but this was already taken care of on Dieselbombers. Turns out that the lift pump is weak on most dodges, so any added power and they start lacking. I was told 5-8psi is normal crusing psi. Thanks anyway.
link to dieselbombers http://www.dieselbombers.com/index.php?referrerid=1849
Dodgezilla
Post by Dodgezilla »
That is correct. Mine, however, must be an extra good one because idle pressure stays around 10psi and it never drops below 4-5psi even on a WOT pull. I made my numbers with the stock LP and pressure stayed fine....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
