Hi folks,
I have the P0128 coolant temp too low CEL after setting fan temps and installing a 180 degree stat. Can you please update my tune to clear this CEL?
P/N: U7135
v.9r23
2006 Dodge Magnum SRT8
Thanks!
P0128 CEL. Can I have my map updated?
- Magnum Tune.drg
- (5.25 KiB) Downloaded 423 times
Here you go.
- magnum_tune_fixed.drg
- (46.91 KiB) Downloaded 437 times
Re: P0128 CEL. Can I have my map updated?
Hi Diablo Folks,
Could I please have another map updated to fix the P0128 CEL issue? I recently installed a Vortech Supercharger and it's included map does not have a fix for this issue, even though they include a lower temp thermostat in their supercharger kit.
Enclosed is my last tune written for this reflash.
Thanks!
Russ
Thanks!
Russ
- Russ' Magnum Vortech Tune.drg
- (10.25 KiB) Downloaded 437 times
here you go.grayforge wrote:Hi Diablo Folks,
Thanks!
Russ
- russ' magnum vortech tune_tstat_fix.drg
- (46.76 KiB) Downloaded 418 times
Perfect... that did the trick.
Thanks!
Russ
Thanks!
Russ
Well, I thought it did the trick, but it may have just slowed the appearance of the CEL. It still re-appears after I reset it.
Can you tweak the previous map you sent to make the low coolant temp CEL go away for good? Can you use the last map you sent or do you need me to send the current map back?
Thanks!
Russ
Thanks!
Russ
post a copy of the current last tune written please.
