Just wondering what PID I can use to check the status of the rear driver's side O2 sensor? What type of reading am I looking for, to determine if it's working properly or not? I have the rears turned off in the tune, but from what I understand, they still need to be able to send a signal to the ECU.
Thanks.
P0137
RE: P0137
You can check the O2 voltage, it should sweep constantly.
My guess is a failed sensor or burnt/damaged harness.
