abs light issue with 2005 ram 1500
greatwhite57
Abs light flashing on 2005 dodge ram 1500 I set the truck to stock and its still tossing need help. I was in wet grass and it spun and the light came on and has been on since. I'm running version 1r08c
greatwhite57
RE: abs light issue with 2005 ram 1500
Need help. Cruise won't work either
to reset that light, sometimes it is suggested to drive in reverse for a hundred feet or so...
- fordomatic69
Re: RE: abs light issue with 2005 ram 1500
With your left foot out the window, your right arm on the passenger headrest and your forehead touching the steering wheelmikel wrote:to reset that light, sometimes it is suggested to drive in reverse for a hundred feet or so...
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
greatwhite57
RE: Re: RE: abs light issue with 2005 ram 1500
I got the light to go out I went back and reinstalled the tune America changed the tire size back to stock
