2004 U7137 cruise control
After I tuned my truck, the cruise control doesn't work anymore. It shuts off once I get over a certain speed. Ive saw on here where other 2004 hemi owners are having the same problem after tuning there truck. Can we expect a fix for this?
RE: 2004 U7137 cruise control
what revision?
Well, I when I got the tuner it was on the 9r04 revision, and then I updated it to 9r12. And my cruise hasnt worked since then, and I updated it recently to 9r13 and its still doing the same thing. So 9r12 is far back as I know.
But like I said, Ive seen other people with 2004 Ram Hemis post on here with the exact same problem.
Put in stock tune and get a dealer re-flash then install new tune. That`s what I had to do to fix mine. No more problems.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
Re: RE: 2004 U7137 cruise control
Does it cost to get the dealer re-flash?lumpy69 wrote:Put in stock tune and get a dealer re-flash then install new tune. That`s what I had to do to fix mine. No more problems.
RE: Re: RE: 2004 U7137 cruise control
I had a tranny flush done so the dealer did not charge me for the flash.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
