2008 GMC Duramax NEED HELP!
John585
Post by John585 »
Hi I Have 08 gmc duramax with a U7186 Predator. Ok here is my problem When I plug the Programmer in. It reads Application Missing or Corrupt. I had installed the Tow setting in the truck awhile back ago with no problems truck runs fine, I went to change the program Yesterday , and now it is saying Application is missing or Corrupt.. I bought the programmer in 2008 had no problems sense now, have not did any updates yet,
RE: 2008 GMC Duramax NEED HELP!
It needs to have the latest revision reloaded to it, basically update the tool.
John585
Post by John585 »
What would be the latest revision. In the updates which update do i use
John585
Post by John585 »
I was reading that u have to put ur truck back to stock before u update the programmers ,but i am not able put my truck back to stock because the programer is saying the application is missing or corrupt,what would happen if i update before i return it back to stock?
Vas@Diablosport
Post by Vas@Diablosport »
If the tool says application missing or corrupt, than it is likely that someone already tried to update the tool, so you have nothing to worry about.
Follow these update instructions:
https://www.diablosport.com/spages/supp ... Legacy.pdf
No, i don't work here.
