Missing PID's with U7315
houseofpower
Post by houseofpower »
Attempting to data log with the Data viewer the normal PID's i.e. knock retard short term, engine rpm, stft's ltft's and ignition timing. I'm running the latest versions and crom files. I've called into diablosport about this and I'am still waiting a response while the car just sits on my dyno. Has anyone else experienced this problem and if so how did you correct it? Thanks in advance.
RE: Missing PID
If live streaming, you should get a full PID list at the right when you connect with the tool.
Select the params you want to see from that list, and then start logging.
MikeWDiabloSport
RE: Missing PID
Post by MikeWDiabloSport »
Connect the Predator to the vehicle and your laptop. Click on the lightning bolt icon in the icon bar at the top of the screen.
It should poll the PCM to show what PIDs are available. You should now be able to pick which PIDs you would like to log.
Jected
RE: Missing PID
Post by Jected »
Will the new update fix the bug between the Predator handheld and data viewer.
Thanks in advance.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
johnc
RE: Missing PID
Post by johnc »
Yes
johnc <at> diablosport.com
