Hi There,
I bought an inTune for my 2007 New Body Silverado 2500HD with a big commercial truck caps (7 feet high).
The load in this pick-up is about 3000 or 3500 pound always.
My goal is to save gas but want to keep this pick-up for a long time...
Should I use GPMS setting or I am better to use a stronger setting to avoid that the pick-up work too much?
Is it possible to have more informations about all the settings?
2007 Silverado 2500HD - 3000 or 3500 pound w big truck caps
Sailman_29
RE: 2007 Silverado 2500HD - 3000 or 3500 pound w big truck c
What is the GPMS setting you refer to?
Best bet would be to use the mileage booster tune.
Sailman_29
Tank you for your answer,
Sorry I was refer to MPG Booster. If I want to try an other setting what are you suggesting?
I forgot to mention that the eingine is a 6.0 L gas 6 speeds.
I think that I need a pin calibrate the touchscreen?
Silverado 2500HD 2007
inTune WITHOUT TCM SUPPORT
Sailman_29
Why there is 2 speed limit?
"Speed Limit 1" and "Speed Limit 2"?
set them both to the max value or to 'off'.
