"This Vehicle Needs an Update Download Here.."
RE: Re: RE: Re: 2007 Dodge Ram - updated and now what!?
Its going to need to be reset...or let it finish the cal update on the vehicle it failed on.
Usually a turbo timer is responsible for tis type of issue...
Unfortunately, the vehicle is gone. What is entailed with a reset?
call us with the tool powered up...
OK, will do today.
Looks like tech support got me fixed up! Thank you all for your help!
Daytona1445
How long should it take for the DCX update to install on to my 05 Ram?
Even with a good battery is a low amp battery charger a good idea?
battery charger wont hurt
Ej205at30PSi
03PTGT my problem is the same as everyone. I have updated to 9r22 and still get "Predator does not support this vehicle call 561-bla bla> my CALid is 04510056ad. I thought i did everything i needed to do, but FAIL everytime. HELP.
im on the stage 1 pcm and 5 speed
Hmm...we support the 055AD cal, but not 056. Not sure why, but i have no way to add stage cals at this point, any chance someone can change the calid inthe ECU?
Ej205at30PSi
So should I put in the stock ecu? Will that work.
more likely, yes.
Ej205at30PSi
so stock ecu, with bigger injectors and the 93 tune, ill be able to start tunning away then? i dont have to rescale the injectors or anything? they are the ones that come with stage 1. Hope it works, or i have a $350 paper weight lol. Thanks.
Karma is what it is, my wrx dosnt like me driving the gt.
ideally you'll need an injector rescale.
Ej205at30PSi
Old ECU worked, updated worked, tune went in. BUT. I only see 14psi that tappers down to 10psi...thats way low for the 93 tune, no? should be 18 or so i thought?
