Tuning Support for 2010 Camaro SS A6 Transmission
KirkShore
Post by KirkShore »
Hi Support,
I downloaded the latest version of the Diablo Software for my T1000. I have a 2010 Camaro SS/RS with an automatic transmission. The version of software on my trinity is:
Part: gm_can_gas
Verion: v.1r08i
The tool successfully created backups of the PCM and the TCM. I have attached those for your review. When I applied the Diablo Tune it did write the tune for the PCM, but did not tune the TCM. When I call support the said it was due to the TCM not being support yet. I have supplied the original backups of both the PCM and TCM for your review. Please let me know when support will be available for my transmission. If you need additional information please let me know.
Kirk
TCM_249179246432.grg
OEM Transmission Backup
(50.12 KiB) Downloaded 128 times
PCM_635863635292.grg
OEM Engine Backup
(67.95 KiB) Downloaded 124 times
RE: Tuning Support for 2010 Camaro SS A6 Transmission
we'll get it added asap.
KirkShore
Post by KirkShore »
Thanks please shoot me an email when it ready to go.
KirkShore
Post by KirkShore »
Any Updates?
Re: RE: Tuning Support for 2010 Camaro SS A6 Transmission
KirkShore wrote:Any Updates?
here you go.
trinity_gm_can_gas-1t08ja_update.crom
(1.42 MiB) Downloaded 124 times
cgworth
Post by cgworth »
I need this as well same part# and version number
Upload your TCM backup.
cgworth
Post by cgworth »
ok tcm backup is attached, I did not seee the one above until after my screen refreshed , can i not just use the update attached above?
(50.12 KiB) Downloaded 120 times
Its the same TCM, so you should be able to use it.
that's an old revision tho.... update to the latest 1r08k trinity release update... if it still doesn't support your tcm and you can't install a tcm tune, then you will have to wait for them to make a new update...
restore original backup to your car... then connect trinity to your pc... when it boots up and gets to the main screen, start up the dsdownloader software and it will automatically download and update the trinity with the latest revision updates...
then go through and select your vehicle again once it's done with everything...
then connect to your car and install a tune, and see if it lets you select a TCM tune...
if not, then you'll have to wait for a new update...
Return to “Trinity GM Gas”
