Installed predator on my 05 ram and now lights are on
05ram2500
Post by 05ram2500 »
u1737 part #
Put this programmer on today and the abs and park brake lights are on now, whats the prob? any help will be much appreciated.
RE: Installed predator on my 05 ram and now lights are on
You turned off Traction control.
05ram2500
Post by 05ram2500 »
The truck is a 2005 ram 2500 4x4, didnt know the truck had traction control. What do I need to do to fix the problem.
What Revision are you running? It will say on the top when you plug in the unit. It'll be 8rxx or 9rxx. If its an 8r version you need to put your stock backup back on the truck and update the tool.
In the Modify Tune section, there should be a selection for either Traction Control or Dyno Mode. If its Traction Control, make sure its ON, if its Dyno Mode, make sure its OFF.
If that doesn't do it then I have no idea what the problem is and you'll have to wait until the Tech guys come in tomorrow.
05ram2500
Post by 05ram2500 »
it is a 9r13
LeHemi
Post by LeHemi »
If it is traction control it should reset when the key is cycled i think.
did you adjust tire size?
bighemitex
Post by bighemitex »
sounds like you wiped out your abs info and a dealer reflash is probably in your future.
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
bighemitex
Re: RE: Installed predator on my 05 ram and now lights are o
Mike_Levy wrote:What Revision are you running? It will say on the top when you plug in the unit. It'll be 8rxx or 9rxx. If its an 8r version you need to put your stock backup back on the truck and update the tool.
i'm pretty sure the rams don't have traction control options or the dyno mode. it sounds like this guy might have set his tire size while installing a tune and wiped out his ABS info.
