Howdy...
Well...Lets see ...Where to start...
I contacted Lew About a Tune...He Thought it Best to Start Here with My Question...I have a 1998 C5 Corvette with a 2002 PCM...It was a Mail Order PCM With a Modified Stock Tune...In The Instructions for the Predator...It States NOT To Write Over a Modified Stock Tune "Serious Engine Damage could Occur"...
How Would I go about this...Do I send a Copy of the Modified Stock Tune to Lew...To Get a Good Base-Tune to Start with...THEN do the Data Logging to Fine Tune-It...
U7198x
Current revision on the Predator...9r17
1998 C5 Corvette...
2002 PCM...LS6 Motor with 30lb injectors(LS1 Converted)...Long Tube Headers...No Cats...No EGR...Under-Drive Harmonic Balancer...VaraRam Ram Air...85mm BBK Throttle Body...LS6 MAF...HV Oil Pump...Two-Piece Timing Cover...Automatic transmission W/Shift Kit Super Servos & Pinless Accumulators...3:42 Axle Ratio Rear End...305/35ZR19 Rear Tires...
Diablew Tune...
RE: Diablew Tune...
As long as the Predaotr will save the current tune as the 'stock tune' you can load custom tunes based on that file all day.
RE: Diablew Tune...
OK...Thanks for the Quick Reply...
SO...Am I understanding this Correctly...With the Tune Stored in the Predator...I Will Be Able to Modify the Tune and With It being My Old Tune Removed from The car...The Codes that have Been Deleted...WILL STILL Be Deleted???
Thanks...Robert.
Thanks...Robert.
RE: Diablew Tune...
yeah, replied to your email...
and yes, if you select Factory HP Tune, it will save a copy of the current tune that's in the pcm, and you can make adjustements and reinstall a tune... and yes, the "original backup" file that it saves will be a copy of the tune that's in the pcm now, so yeah, all your codes and whatnot will still be disabled... unless the person that tuned the car before has locked their tune, in which case you won't be able to do anything with it...
