Just wondering if my U 7194 will work with windows 7.
I tried to download drivers and only saw XP and VISTA.
Also just got this tuner and it was used on a newer camaro. It is supposed to work with my new body style Gmc sierra. When I took it from the camaro I returned it to a stock tune. I plugged it into my sierra and it wont upload the tune?? Any Advice will be greatly appreciated. Thanks Aaron
Will my U7197 work with windows 7
RE: Will my U7197 work with windows 7
yes.. get the drivers from www.diablosport.com/drivers
what is the exact error message you get when you try to install a tune??
on the predator, go to Options - Show Last Tune Written and what does it say?
When I try to install a performance tune it says calibration not supported or something like that. Then my truck wont start and I have to remove the two Pcm error dtc's. Once I remove the dtc's My truck starts again. Ill try to get the exact dtc's and message later. Dose it sound familliar. Version of software in tuner is v9r17. I have also installed drivers and it wont communicate with my diablo for some reason. Ill try the link you posted. Thanks
need to update that Predator.
For some reason the drivers arent working. I cant update the predator. Mabye Ill try it on a different Computer at work tomorrow.
try turning off the UAC on windows 7... the User Access Control setting.. put the slider all the way down to the bottom to disable it... and make sure your user account is an Administrator Account type...
then reboot the pc, then try it again...
I didnt try that, But I called support and they told me they were having problems with windows and the driver. I tried 3 other computers and finally got it to work. Thanks
