2007 300C 91 Oct Tune - Won't let me adjust Trans info
inTune i1000
2007 300C 5.7
I just bought the inTune. Had some troubles with connectivity. Great Tech Support. Finally got it going. I installed the 91 Octane Tune. I wanted to adjust the Trans Shift Firmness and Shift Point. It kept on saying cannot adjust and kicked me back to the provious screen.
2007 300C 5.7
RE: 2007 300C 91 Oct Tune - Won
I used my InTune to change the Trans Shift Firmness to "Increased".
I have a 2009 Challenger R/T 5.7 Hemi, DiabloSport 91 Octane CAI tune.
I can even go back in the car (tune previously installed) and change it under:
- Tune Vehicle
- Adjustable Parameters
Hopefully a DiabloSport rep will know if it is related to your 2007, or the 300C model computer.
- Tune Vehicle
2009 Dodge Challenger R/T 5.7 Hemi
can you post your calid here?
Hate to sound stupid, what is calid?
settings/tool info/vehicle info
GSPCharger
Re: 2007 300C 91 Oct Tune - Won't let me adjust Trans info
Mine does the exact same thing on my 2010 R/T Charger. After about 10-12 tries, it finally lets me adjust those settings.jkalacin wrote:inTune i1000
2007 300C 5.7
mdeezy10rt
RE: Re: 2007 300C 91 Oct Tune - Won
i have the same problem on my 2010 Charger RT as well.. everytime i try to adjust anything in the transmission part it keeps saying failed.
can you guys post your calids please?
Just got the inTune for my 2010 Charger R/T... I'm also getting a failure message when trying to set the shift firmness. I've used the regular Diablo Tune and am now using the CAI Tune. I noticed after programming that if I go into the Shift Firmness menu, it currently actually says it's set to "Increased." However, if I try changing it to "Stock" or even reselect "Increased" it still gives a failure message.
Firmware Version: 1r01h
Tune DB: 1r01a
Calid: 68052005AD
Tune DB: 1r01a
Calid: 68052005AD
Mine has this problem with trying to adjust shift firmness after updating the InTune to firmware 1r01i.
68061225AD
I have posted this problem before, with no solution.
68061225AD
a fix is in the works.
