gm gearing calibrations
- Oldsaltydog
when will we be getting the rear gearing adjustment update will it come with everything else we are waiting for? 2010 silverado
Oldsaltydog
2007 corvette c6
2007 corvette c6
RE: gm gearing calibrations
you need a tune for gears right now?
he's already got a custom tune, and I changed his gear ratio already...
so what's up Stan??? what is it you want/need to do???
- Oldsaltydog
All is good just. Curious about that my predator had gear ratio changes
I'm sure in time intune will also
Oldsaltydog
2007 corvette c6
2007 corvette c6
aah, gotcha...
I'm surprised it doesn't already, since the gear ratio change is not a TCM thing, it's done in the ECM...
interesting...
interesting...
- Oldsaltydog
Lew that's why I had u change it for me it's on the tool but it does not work I tried it it goes to max when u try to adjust it maybe mike l can shed some light on this cuz if I go back to stock for any reason every thing is out of Waco cuz I can't adjust the axle ratio the tire size works anybody know why?
Oldsaltydog
2007 corvette c6
2007 corvette c6
- Oldsaltydog
- Oldsaltydog
does any one have an answer to this question ?
Oldsaltydog
2007 corvette c6
2007 corvette c6
Sailman_29
It's possible to modify the rear gear ratio with inTune handheld programmer?
Silverado 2500HD 2007
inTune WITHOUT TCM SUPPORT
- Oldsaltydog
Well is this gonna b like Tcm can I get an answer to my initial question?
Oldsaltydog
2007 corvette c6
2007 corvette c6
intune should have the param if Predator or trinity have it.
- Oldsaltydog
back up file
here u go mike is this what u want
- PCM_ORI.grg
- (65.41 KiB) Downloaded 163 times
Oldsaltydog
2007 corvette c6
2007 corvette c6
- Oldsaltydog
RE: back up file
....bump?
I guess Im not sure what you are explicitly after here?
Your tune is good, right?
As mentioned, if you had the param in trinity or pred, it should be in intune, if it is not, we will investigate and get it up to speed, but I cant say it is going to happen last night
RE: back up file
you had asked him for his file in another thread, and you told him to post it over here... so you guys can figure out why the gear adjustment is not working...
he has the gear/axle ratio adjustment on the intune, but when changing it, it doesn't actually change/affect the tune - it doesn't really get changed/written... so you had asked him to post his file here so you guys could figure out why the gear/axle ratio adjustment isn't actually working/writing the change...
