180 stat and emissions 2006 dodge charger r/t
lwright
u7135 crom 30 2006 dodge charger r/t.
Hello, can anyone tell me whether or not that they have had problems passing a emissions test running the jet 180 stat? and if so what did you do to resolve the problem. Thanks in advance for any feed back on this one.
RE: 180 stat and emissions 2006 dodge charger r/t
should not be an issue.
I passed no problem
No issues at all, unless your car kicks a check engine light from the coolant to low, which can happen with the 180 in extreme winters.
The Jet is known to pop codes, but what are the chances it would happen just when he's gettig the inspection done? I always recommend NAPA. Costs about a third as much and never throws codes. Ran it on both my SRT8s and now I'm trying to match one up for the V.
lwright
Thanks fellas for the feed back! I went to Napa for the stat and they did not have one. They sent me to a speed shop that only carried the jet. What is the difference between the two stats for one to be known to throw codes and the other does'nt?
I have no idea what the difference is, just the results. Does the Jet have the jiggle pin?
I doubt your car will kick a code if you allow the fan settings to be factory, unless you're in Alasaka.My dodge ram has the jet 180 and it uses a fan drive system and going by the data log it runs at idle around 190 and driving it's around 185 and still has not kicked a code and has 6k miles on it.
My charge did kick the code when I made the fans come on sooner, but this was in the winter stages,doing the summer it never did.
AS long as your check engine light is off it will pass emissions.
Re: RE: 180 stat and emissions 2006 dodge charger r/t
That depends on the state. In NY if you have any stored codes, whether the light is on or not, you fail.Tech5 wrote: AS long as your check engine light is off it will pass emissions.
Well a code being stored will kick a CEL.NOW if you're talking about if you clear the code and drive short distance and the code pops up but yet triggered the light , that means it has not went thru the readiness test and will fail in any state.Mike_Levy wrote:That depends on the state. In NY if you have any stored codes, whether the light is on or not, you fail.Tech5 wrote: AS long as your check engine light is off it will pass emissions.
RE: Re: RE: 180 stat and emissions 2006 dodge charger r/t
A code doesn't always kick a CEL. There are numerous codes that won't turn on the light. And Readiness forget it, biggest PITA ever. Can't turn off the rear O2s because of that. Some guys do it and get away with it in other states though.
If you have lowered fan temps, just let it warm up before driving. Thankfully no emissions tests or inspections here in SC.
2010 Challenger SRT auto
Black - stripe delete
CAI
Pred
180 t-stat
mopar cat back exhaust
CAI
Pred
180 t-stat
Re: RE: Re: RE: 180 stat and emissions 2006 dodge charger r/
If some codes do not turn on a light what good is it. If its not puting on a light then the car will show ready when to go through emissins testing.Mike_Levy wrote:A code doesn't always kick a CEL. There are numerous codes that won't turn on the light. And Readiness forget it, biggest PITA ever. Can't turn off the rear O2s because of that. Some guys do it and get away with it in other states though.
RE: Re: RE: Re: RE: 180 stat and emissions 2006 dodge charge
Minor codes don't turn the light on. I used to get that all the time on the Jeep. No light, but scan the computer and there would be 4 or 5 stored codes.
