2008 U7186 9r15 tune wont install
fastmatt007
fastmatt007
Our diesel tuner tried yesterday and flashed all the tunes to a PCM with your VIN in a PCM.
It is possible that we got different calibrations than you, but not likely.
Can you post a copy of your stock tune her so we can confirm?
monkey62803
Hi, I have the same truck, '08 LMM and I'm having the exact same problem. I tried 6 times this weekend to load the tow program and it keeps returning the ECM Lock Error. It normally takes me several attempts to load a program but now it won't do it at all. I removed the 3 fuses but to no avail. Help??
can you post up a copy of the stock tune?monkey62803 wrote:Hi, I have the same truck, '08 LMM and I'm having the exact same problem. I tried 6 times this weekend to load the tow program and it keeps returning the ECM Lock Error. It normally takes me several attempts to load a program but now it won't do it at all. I removed the 3 fuses but to no avail. Help??
martinouellette
monkey62803
I have no idea how to post the stock tune??? I tried again yesterday to install a program and got the same ECM lock errormikel wrote:can you post up a copy of the stock tune?monkey62803 wrote:Hi, I have the same truck, '08 LMM and I'm having the exact same problem. I tried 6 times this weekend to load the tow program and it keeps returning the ECM Lock Error. It normally takes me several attempts to load a program but now it won't do it at all. I removed the 3 fuses but to no avail. Help??
OK, we're investigating...
monkey62803
