2007 GMC Sierra--ABS/Brake lights still on
Still working on this for the intune as well as trans support, in the mean time give the attached file a shot. All the adjustments you had in the last tune written are already done here so there should be no need for you to adjust anything with this one.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
be sure to reset parameters when installing this tune.
adammannis
adammannis
can you post the LTW please?
did you change tire size when you loaded the tune?
adammannis
adammannis
My 2007 Abs lights are still on. I have 22 inch wheels and tried using stock size parameter and actual sizes 285 45 22 and no matter what light keeps coming on as soon as I reach highway speeds. Is this tune above his specifically or can I download and try his tune as well. I have Gm performanc parts cold air intake no cats, corsa 3 inch exhaust.The last update I tried dosent work. My version is v.9t30q. Thanks Aaron
adammannis
adammannis
Ok guys it's been 2 months today and still no fix. What exactly do I need to do to become a priority? I hoped being loyal and giving you ample time would be the key. But you guys have obviously taken my patience as some kind of indication that I am some kind of push over and that could not be farther from the truth. I need a resolution on this problem.
